Email firmware notifications?
Hi @mat17, and @valerio_vanni,
You can register devices in below link.
We will send notification mail when new firmware is released.
https://www.zyxel.com/global/en/form/product-registration
Hi @mat17,
You should be able to receive new firmware notification from Myzxel.com when it is registered.
Hello,My firewall is connected and registered in the portal.Unfortunately, as far as I know, I never received an email notification about a new firmware.And for my AP, it is also registered in the portal, but there is no way to connect it to the portal from its administrative panel.Do I have to do something special to get these notifications?Kind regards0
Neither I get email notifications.The only notification I get is in web interface of device when I log on.In portal.myzyxel.com, under "device management" there is a button "firmware update". If clicked, it answers "up to date". Don't know if there's any notification when it's not updated.0
@Zyxel_Cooldia hi, maybe I'm wrong here but.
- For register a device, I should have a Myzyxel account.
- For have a my zyxel account, i need an email addres
so why there's not an option in MyZyxel or in Nebula as "notify with email when this device has a new firmware available"? MyZyxel portal already notify if a licence is going to expire...Any MyZyxel portal knows public IP and firwmare version of every device...0 -
Hi @mMontana,
About the new firmware notification mail from Myzxxel.com, we will move this suggestion to ideal section for future evaluation. Thanks for your suggestion.
Hello all,from my side, the portal accesss was not the right solution because:- not all your products have a portal access- for my firewall, which has a portal access, I don't get any notifications about firmware updates.I'll see then if the product registration solves this issue.Thanks.0
Don't forget the option on Nebula. Option for notification.Zyxel_Cooldia said:Hi @mMontana,
Hello @Zyxel_Cooldia
As I told you, I registered all my devices.
There was recently a firmware update for the USG FLex 200. But unfortunately, I didn't get any email notification.
How can we get notified when there is a firmware update in one of our products?
Kind regards
- 603 USG FLEX H Series
- 481 News and Release
