Send Magic Packet to Wake a Computer from a NAS326
mangu
Sorry for my english...
I have installed ffp and i can not find an option to send a magic packet to wake a computer in the home network. I want to SSH to the NAS and send the magic packet from it, because my router loses the arp table when i shotdown the computer.
Is there a way to do this?
This seems to be impossible mission...
Nah, that's not so bad. I jst pointed to an ether_wake.c with some garbage. Try this one instead:
https://gist.github.com/erichschroeter/9884006
As far as I know ffp has no WOL package. But most slacker sites are dead links now.Sending a WOL packet is no rocket science. It's any ethernet packet which contains in it's payload 6 bytes FF FF FF FF FF FF, followed by 16 times the 48 bit (6 bytes) MAC address of the device-to-be-waked. In practise an UDP broadcast packet is used, send to port 0, 7 or 9, but that doesn't actually matter.There are several implementations around, a shell script, a perl script and a python script. I didn't test any of them in ffp.When you have the ffp build tools installed, you can also build a binary. Download ether-wake.c and compile it:gcc -o ether-wake ether-wake.c
Thank you for your answer Mijzelf. I´m trying to follow some tutorials to install ffp build tools to compile etherwake, but i keep getting errors. I dont know if these tutorials are outdated but i cant install build tools.Im following this guide https://nas-tweaks.net/106/compiling-software-for-the-fonz-fun_plug/ and this https://github.com/Darkvater/ffpbuildenv.In those, it says "install ALL packages available as described in the linked tutorial" but i cannot find what are those packages. Sorry, im a little bit familiar with Linux but the normal commands there, cant be used here
I have try also the scripts but i cant do them to work.Thank you in advance.
I think that for just executing 'gcc -o ether-wake ether-wake.c' you only need to install gcc, binutils and mpfr.
Hi Mijzelf. I have installed those packets and i can compile it now, but i get this error in the process.
root@NAS326:/i-data/-------/admin/WOL# gcc -o ether-wake ether-wake.c
In file included from /ffp/include/errno.h:36:0,
from ether-wake.c:61:
/ffp/include/bits/errno.h:25:26: fatal error: linux/errno.h: No such file or directory
compilation terminated.
When you look in Fonz' repository https://ffp.inreto.de/ffp/0.7/arm/packages/you see a file MANIFEST.gz, which contains a full file listing of all packages. If you search for 'linux/errno.h' you can see that it's provided by package 'linux-headers'. So install that package.
Seems that this dont want me to wake up my computer hahah
root@NAS326:/i-data/------/admin/WOL# gcc -o ether-wake ether-wake.c
ether-wake.c:87:23: fatal error: interface.h: No such file or directory
compilation terminated.I have searched in the file that you mention, MANIFEST.gz, and i cant find "interface.h" . The only one i find is "zend_interfaces.h". This seems to be impossible mission...
OMG!! It worked!! You are a genious Mijzelf!!Now my NAS is perfect
Thank you very very very much!!Merry Christmas and happy new year!!
- 237 Nebula Ideas
- 6.8K Security
- 744 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
