Zywall 110 show running-config error
Hi
Zywall 110 V4.73(AAAA.0)
Log in to ssh with 'limited-admin' and execute 'show running-config'. Received error 'ERROR: Insufficient privilege.'
From manual:
limited-admin - this user can look at the configuration of the Zyxel Device but not to change it.
How can I get config from 'limited-admin' via ssh?
Hi @dv_berg i think that this behavior is intended.With the request to show the running config, the limited-admin user could "steal" the configuration of the device redirecting the output to a text file.So.Please, with the same limited admin user, try to download any of the configuration files on the device from the web interface. If this happen, smells like a bug to me...0
Yes, looks like it is intended. Just tried to download config file and get the same error.Still, I think its a bug. At least it must be described in the manual.0
Due to the consistency of the behavior, I agree with your for document the behavior in the manual, but it's not a bug IMVHO.dv_berg said:Still, I think its a bug. At least it must be described in the manual.Some security data is present into configuration so limited-admin without that access has some meaning that I can understand (share or not is quite tough explanation for this topic)I hope that some zyxel representative can share more "official" info about that.0 -
Hi @dv_berg,
Greeting forum.
The statements " limited-admin - this user can look at the configuration of the Zyxel Device but not to change it" means that you can see configuraton on WebGUI not include "text" format (show running-config) .
Thanks your advice.
Thank you
Kevin
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 299 Service & License
- 482 News and Release
