Armor G1 / USB Zugriff einrichten
Cappi13599
in Home Router
ich suche eine verständliche Anleitung in deutsch um meinen angeschlossenen USB Stick einzurichten als Speicher für meine Überwachungskamera.
-1
What is the size of your USB?
If it is a large size of USB, it needs power adapter for it.
You can check put the laptop under the Armor G1 device and go to file explorer to check if USB has mounted on it.
Try with \\192.168.123.1\0 -
der USB Flash Speicher hat 512GB0
Which model of the USB you're using?
Is it USB 3.2 Gen 1、USB 3.2 Gen 2、or USB 3.2 Gen 2×2?
As the spec, it support USB3.1
https://download.zyxel.com/Armor_G1_(NBG6818)/datasheet/Armor G1 (NBG6818)_3.pdf
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
