[NEBULA] Content filtering blocks video streaming?
Hi.
After the last update, the NSG100 blocks video- streaming from certain apps(Viaplay is one example) on an LG TV.
Disabling content filter makes it work again.
Appletv on the same networkbstreams Viaplay fine with content filtering enabled.
Before the latest update the LG TV also worked fine with the filter enabled.
May be an odd question, but what can be the reason for this? I also tried disabling all of the categories in the filter, still no go.
Weird!
-Christian
Weird!
-Christian
Hello @ComNet
I think this matter is regarding to the cache, after disable all of the category, the device will still keep the cache for 1 to 5 minutes, during this time if you try to refresh/reconnect the website, the counter will be reset then get block.
/Chris0 -
Hi.
The customer has now tried to leave all categories off for the last 24 hours without using the TV. Streaming is still blocked just by having the content filter enabled.
-Christian0 -
Hello @ComNet
Thanks for your info. I can help to get further check with this case, I'll private message you with the relevant questions, please check your message inbox.
/Chris0
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 498 USG FLEX H Series
- 323 Security Ideas
- 83 Switch Ideas
- 49 Wireless Ideas
- 286 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
