SecuExtender 4.0.3.0 (windows) not working (VPN connection still ok)
ok, i fixed it :
-uninstall secuextender
-reboot
-uninstall all wan card in device manager
-clean the registry (with ccleaner in eg)
-reinstall secuextender
ok, i fixed it :
-reboot
Same Problem here. I'm connected but can't access the remote network. The virtual LAN adapter doesn't receive any data. When i try to reinstall Version 4.0.2. I get the error "Invalid command line"
and when i try to remove the WAN-Card manually i end up with an error "Client for Microsoft networks could not be removed" 0x80071779.
Can anyone help me how to get a working System again?0 -
I had the same issue before and their tech support gave me a patch. I upload it and it still working fine. You can call them and ask for the patch.0
Zyxel_Emily said:
the firmware update fixed the issue. I hope the firmware will be released soon officially so less people have to come here to get the fix manually.
But thanks for the fast support. Very appreciated!0 -
Hi, will the update be official?
Hi @TommyD,
Yes, we confirm that SSL VPN will be working fine in the next official release 4.33. It will be released in late December.
- SSL VPN tunnel can be established.
- After SSL VPN tunnel is established, ping USG’s LAN subnet successfully.
@Zyxel_Emily Hello there! We are experiencing the same issue with a USG 110 running 4.32(AAPH.0) firmware. Can you please send the firmware via DM as well? Thank you0
Hi I have several devices that are working with local accounts but AD accounts are failing to connect to the SSL VPN. USG 40 and 20's.0
- 439 Beta Program
- 190 Nebula Ideas
- 6.2K Security
- 466 USG FLEX H Series
- 305 Security Ideas
- 81 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
