I cant setup dualband... USG20W-VPN Router
Posts: 3  Freshman Member
edited April 2021 in Security
Our small uncommercial organization just bought a  USG20W-VPN Router.
I have reaaly trouble setting up this router....
First of all, I try to setup a Wifi. It works fine with a 2.4Ghz-band.
Also I'd like to setup another SSID / band with 5Ghz...
I succeeded setting up a new SSID - but..... this is also 2.4Ghz... where do we do that?
Please, I hope you can help us. Our TV does only have a 5 GHz network-adapter...
Best regards
Carsten
carjuth
Welcome!
It looks like you're new here. If you want to get involved, click on this button!
  • Posts: 3  Freshman Member
    edited October 2018
    USG20W-VPN is single radio so you can have it operate on either 2.4Ghz or 5Ghz but not both.
    Ted
    Its a pity .... Im glad that you could tell me that :-)
    Is that still the case with the USG20W-VPN?  Will it only connect on 2.4 and 5 even with two profiles?
  • Posts: 151  Master Member
    I don't think so, you'll need to add external zyxel ap (managed by USG20W-VPN) to support this
Welcome!
Welcome!
