[Release Note] Access Point Series - V6.40 P6 firmware has been released!
Zyxel_CSO
Zyxel_CSO Posts: 504 image  Zyxel Employee
5 Answers First Comment Friend Collector Ninth Anniversary
edited October 2023 in WirelessLAN New Release
Access Points Firmware Release Note V6.40 Patch 6
Date: July 14, 2022
Supported Platforms
NWA110AX V6.40(ABTG.6)
NWA1123ACv3 V6.40(ABVT.6)
NWA210AX V6.40(ABTD.6)
NWA220AX-6E V6.40(ACCO.6)
WAC500 V6.40(ABVS.6)
WAC500H V6.40(ABWA.6)
WAX510D V6.40(ABTF.6)
WAX610D V6.40(ABTE.6)
WAX620D-6E V6.40(ACCN.6)
WAX630S V6.40(ABZD.6)
WAX640S-6E V6.40(ACCM.6)
WAX650S V6.40(ABRM.6)
New Feature and Enhancements
1.             Support new AP model. The NWA220AX-6E, WAX620D-6E and WAX640S-6E are added to Nebula in this release. NWA220AX-6E is a NebulaFlex AP that supports standalone and Nebula cloud managed mode; WAX620D-6E and WAX640S-6E are NebulaFlex Pro AP that comes with 3 management modes: standalone, controller managed and Nebula cloud managed modes. It comes with 1 year Nebula Pro Pack license bundled.
2.             The U/I of WiFi settings are enhanced for WiFi 6E (6GHz).
3.             Support more radio settings correlated while selecting deployment template on Nebula control center.
4.             Added MAC authentication fallback option that allows a wireless client to bypass captive portal if a station passed MAC authentication on Nebula control center.
5.             Improve log wordings to easy of read and more detail information for troubleshooting.
6.             Support WPA3 security option on Standalone AP wizard.
7.             Device login page enhancement to add more on-boarding information.
Bug Fix
Empty column stands for the mode is unaffected.
 CLD=Cloud mode, MGNT= Management mode, STD=Standalone mode
Mode
CLD
MGNT
STD
1.       [eITS: 211000247]
[Symptom] Cannot get any of the access points to upgrade their firmware
V
2.       [eITS: 211200358]
[Symptom] Fast roaming doesn't work with DPPSK, clients get default vlan IP after roaming
V
3.       [eITS: 220200710]
[Symptom] When user set Emoji on the default SSID, no pop-out window
V
V
V
4.       [eITS: 220100520]
[Symptom] Fix TCP port 83/84 need to be turned off problem when using vulnerability scanning
5.       [eITS: 211200432]
[Symptom] configure dynamic VLAN. Clients get original SSID VLAN IP
V
6.       [eITS: 220200256]
[Symptom] Mesh SSID is visible and called ’smart_mesh’ and ’SG_xxxxxxxx’
V
Known Issue
Mode
CLD
MGNT
STD
1.       [eITS: 220601044]
[Symptom] Accounting packet missing Framed-IP attribute
V
 V
2.       [eITS: 220400788]
[Symptom] 802.11AX QCA model reboot caused by NSS abnormal
V
V
V
3.       [Symptom] WAX620D-6E, WAX640S-6E, and NWA220AX-6E LED would still display blue light even if stations are connected.
V
V
V
4.       [Symptom] WAX620D-6E, WAX640S-6E, and NWA220AX-6E ipv6 dhcp6 address-request not get ipv6 address
V
V
V
5.       [Symptom] Client will disconnect if it first reauth fail after Fast Roaming
V
V
V
Limitation of Settings:
1.    Due to hardware limitations, the AP throughput will be limited to 60Mbps when the rate limit, Dynamic VLAN assignment, DPPSK is enabled on NWA220AX-6E, WAX620D-6E, and WAX640S-6E.
Zyxel Nebula Support
  • Asgatlat
    Asgatlat Posts: 130 image  Ally Member
    First Comment Friend Collector Eighth Anniversary
    edited July 2022
    hello,
    not yet available on support website ? edit : released ;)
  • Jason210
    Jason210 Posts: 5 image  Freshman Member
    So where is it? My device is stuck on 6.10
