VLAN tagged frame handling on the XGS1210-12
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,623 image  Zyxel Employee
    Hi @papu,
    Do you need the date firmware? Feel free to PM me if needed.
    Zyxel Melen
  • eolo
    eolo Posts: 35 image  Freshman Member
    +1 encountering this ingress filtering issue as well. Need the firmware with ingress filtering release date.
  • Zyxel_Melen
    Hi @eolo,
    Thanks for asking.
    I will give you an update about the ETA date.
    Also, I will send the date code firmware to you via PM, please check the mail box.
    Zyxel Melen
  • ChrisMini
    ChrisMini Posts: 1 image  Freshman Member
    +1 i would need ingress filtering too :)
    Would be nice to get an update.
    BR
    Chris
  • Zyxel_Melen
    Hi @ChrisMini,
    Welcome to the Zyxel Community!
    I have sent the date code firmware to you via PM.
    Please check your mailbox. Thanks.
    Zyxel Melen
  • Zyxel_Melen
    edited October 2023 Answer ✓
    The latest firmware includes the ingress VLAN filtering feature (VLAN ingress checking).
    Please download it via this link.
    Zyxel Melen
  • saqib_s
    saqib_s Posts: 7 image  Freshman Member
    Hi Melen,
    Thanks for providing this, can you explain how this file / firmware is different to the version available under the official link here:
    I've downloaded your file and the one from the below link and the files are different,:
    File from User Zyxel_Melen:
    Size: 6411077 bytes (6260 KiB)
    SHA256: 259aac55b1a08c1847305084322edece9818449f5523bc1c91fd870052aaff7e
    File from the Official link below:
    Size: 6378757 bytes (6229 KiB)
    SHA256: 4ff75d34efe068890587774464093cc1ca0fc6db376a141854763dfb77eb7976
  • Zyxel_Melen
    Hi @saqib_s,
    The difference is that the date code firmware adds ingress filtering by default. This is used to avoid receiving packets with the VLAN ID which does not belong to this port, and flood to that VLAN member ports.
    Zyxel Melen
  • saqib_s
    So the file you've posted is the date code firmware. Will this feature be included in the a main branch upgrade in the future?
  • Zyxel_Melen
    Hi @saqib_s,
    Yes, this feature will be included in the next official firmware. I will inform you once it is released.
    Zyxel Melen
