Options to extend log numbers?
mat17
mat17 Posts: 45 image  Freshman Member
Hello support,
Just wondering if we are able to configure the log number entries in a USG FLEX unit? (a 200 one).
For now, my logs are rotated twice, sometimes three times a day, and it's difficult to investigate an event.
My logs are emailed, and send to a syslog server too, but:
- it's not comfortable when you have multiple emails to browse
- for now, I have a problem in the generated syslog format received by my syslog server
Thanks for your answer
  • StefanZ
    StefanZ Posts: 202 image  Master Member
    First Comment First Answer Friend Collector Second Anniversary
    Things you can do:
    • Set logging for rules like the “default rule” to "none", so that not every dropped connection attempt gets logged.
    • Change the logging levels so only important stuff gets logged (quite limited option tho)
    • USE USB for log storage (which of cause isn't convenient to grab daily, it's more of an insurance)
    • Use a Syslog logging server like Graylog
  • Zyxel_Emily
    Hi @mat17,
    USG FLEX 200 supports up to 1024 log entries. If you'd like to investigate an event, we suggest you use SecuReporter. Here are some useful articles for your reference.
  • StefanZ
    Things you can do:
