IPSEC Client: Access to host via Site2Site VPN
I have the following scenario: Users connect with the Zyxel IPSEC Client to the local network 192.168.37.0/24. Now these users should also be able to access resources which are connected via Site2Site VPN. I found the following article:
But this does not work, because from the client point of view only the network 192.168.37.0/24 is routed into the tunnel; there is also only such a policy on the Zywall:
Now how can I tell the VPN client that the Site2Site network should also be routed through the dialup tunnel? Set up a second Phase2 on the Zywall and on the IPSEC client?
Thanks in advance for any help!
martin
martin
Hi @humschti,
Thanks your time today, the issue have been resolved after change Local Policy to the correct subnet.
Please feel free to contact me if any concerns.
Thank you
Kevin0
Hi @humschti,
Greeting Forum. Please kindly share your config file by private message.
I will check if there is something missing.
Thank you
Kevin0 -
Hi @humschti,
Thank you
Kevin0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
