IPSEC Client: Access to host via Site2Site VPN
humschti
humschti Posts: 8 image  Freshman Member
I have the following scenario: Users connect with the Zyxel IPSEC Client to the local network 192.168.37.0/24. Now these users should also be able to access resources which are connected via Site2Site VPN. I found the following article:
But this does not work, because from the client point of view only the network 192.168.37.0/24 is routed into the tunnel; there is also only such a policy on the Zywall:
Now how can I tell the VPN client that the Site2Site network should also be routed through the dialup tunnel? Set up a second Phase2 on the Zywall and on the IPSEC client?
Thanks in advance for any help!
martin
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 959 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @humschti
    Thanks your time today, the issue have been resolved after change Local Policy to the correct subnet.
    Please feel free to contact me if any concerns.
    Thank you
    Kevin
  • Zyxel_Kevin
    Hi @humschti
    Greeting Forum. Please kindly share your config file by private message.
    I will check if there is something missing.
    Thank you
    Kevin
  • Zyxel_Kevin
    Hi @humschti
    Thank you
    Kevin
