PIXELATED IMAGES IN AUTOCAD GEOMAP LOCATION
Every time when they open the GEO LOCATION MAP in the AUTOCAD application and search for the address of the map, the images are pixelated and it takes a longer time to load fully load it.
How i can UNBLOCK or EXCLUDE it in the URL THREAT FILTER and make it ACCESS FORWARD? Anyway, the model of firewall that I used is ZYXEL USG FLEX 100. Please see the attached image file. Thank you so much for the help.
Best Answers
Hi @Rodnie,In the log, it seems you already added the following URLs to Allow List in URL Threat Filter.ecn.t0.tiles.virtualearth.netecn.t1.tiles.virtualearth.netecn.t2.tiles.virtualearth.netecn.t3.tiles.virtualearth.net
Besides, the query result of these URLs is not categorized as threat, so they are not blocked by URL Threat Filter. You can check the logs and see if the traffic is blocked by other security services.
Hi @Rodnie,If you create a rule in Security Policy > Policy Control using FQDN, even if the traffic matches the rule and passed, the passed traffic will then be detected by URL Threat Filter. Here is the packet flow of USG FLEX for your reference.
Thank you so much, it's a big help to me. How can I unblock these from the URL THREAT FILTER? Is there any other way that it can be exempted from the security policy or any other security services?0
Hi @Rodnie,You can use the feature Security Service > IP Exception to bypass specific security services based on the packet’s source or destination address.1
Thank you so much for the help. What if I will make a policy in the POLICY CONTROL using FQDN, is it possible that will not be filtered or blocked by the SECURITY POLICY CONTROL?0
Thank you very much. Can you teach or help me with how to do that?0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
