Legacy firmware for Zywall USG 200
Thank you Kevin
unfortunately, also the 2.20 AQU.6 gave me the same error.
at that point, I would try the release 2.20(AQU.2)C0 if this version work I probably really need to install all the release in order.
Can you please provide version 2.20(AQU.2)C0?
Thank you Kevin,
version 2.20(AQU.2)C0 was finally working, and after I was finally able to install in order the versions
2.20(AQU.6)C0
3.00(AQU.0)C0
3.30(AQU.5)C0
3.30(AQU.7)C0
I have 2.20(AQU.4) and need to upgrade to 2.20(AQU.6) before upgrade to the latest firmware. Can you PM me the require firmwares? Thank you.
Hi
I'm looking for 2.20(AQU.6) firmware,
Can someone PM me with this ?
thank you !
I need to bring the firmware of my ZyWall to the latest/last released version. Currently I have Boot Module 1.12 and Version 3.30(AQU.7). Are there any intermediate steps I need to perform?
The problem I intend to resolve is the outdated method used for HTTPS.
Thanks and Regards, Klaus
I suggest that upgrade version by version. May I know what's your current version? I will send the firmware file you need via PM.
- 434 Beta Program
- 174 Nebula Ideas
- 418 USG FLEX H Series
- 297 Security Ideas
- 43 Wireless Ideas
- 270 Service & License
- 416 News and Release
- 87 Security Advisories
- 4.1K FAQ
- 87 Security Highlight
