Which Wan IP ? Lete7490-M904
JMB_74
LTE7490-M904:
Home/Cllular info: ip address = 10.106.xxx.xxx.
MyWanIP on internet navigator = 185.55.xxx.xxx.
So which is the correct Wan IP ?
Thank's.
Regards.
Fred.
Best Answers
For the router: 10.106.xxx.xxx.For internet: 185.55.xxx.xxx.Your provider use C-NAT
Hi Fred @JMB_74
I think that your ISP probably has the mapping already in their Carrier Grade NAT but will probably not let connections through it to your LTE7490-M904 device.
What behaviour do you get today if you try a traceroute / tracert to your 185.55.xx.xx address?
You may need to talk to your cellular provider to see if they will let inbound connections through or not from the Internet.
Kind regards,
Tony0
Hi,thank's for this information.So now, which ip using to access the router from internet ?Do I have to create a NAT rule from internet ip to router operator ip ?Regards.Fred.0
Hi Fred @JMB_74
Kind regards,
Tony0
- 243 Nebula Ideas
- 6.9K Security
- 793 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
