SSL VPN still available?
Dpj
Dpj Posts: 197 image  Master Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
Knowledge Base | Zyxel
I was wondering if this option is still available with the newest firmware and an zyxel usg flex 500.
I would like to use this for users who want to connect to an internal website with their mobile devices.
I cannot find it anymore i the settings. (SSL vpn of course there is, but the next part i cannot find.)
  • mMontana
    mMontana Posts: 1,443 image  Guru Member
    AFAIK it should. But "their mobile devices", if are Android or iOS devices, won't work with SSL VPN, due to a not-standard OpenVPN implementation used on this feature.
  • Dpj
    the part application is missing on my usg 500.  so i think this is not supported annymore. Then i have find an other solution
  • mMontana
    You can create users also outside this specific section of interface...
  • Dpj
    Users is not the problem, but applications
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 959 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    edited January 2023
    Hi @Dpj,
    Greeting Forum,
    The Knowledge Base is for old module/Firmware. FLEX/ATP series no longer support that.
    Thank you
    Kevin
