GS1100-16 not working with new 5g modem
I have GS1100-16 for my home network.
I used it with 3g modem, then with 4g modem and it worked fine.
Now I bought new 5g modem (zte mc888) and it doesn't work with my GS1100-16.
I found a temporary way around - connect my modem to google wifi hot spot (by cable) and the google wifi to Zyxel switch (by cable). In such way it works, but not when modem is connected to the switch directly.
Please, help!
Justas
Please, help!
Justas
Did you already tried to replace the LAN cable between GS-1100-16 and the router?0
Yes. This was the first thing I tried changing.
Cables are fine .0 -
Hi @Justascom,
We suggest trying to configure port speed with force 100M full-duplex or 10M full-duplex on your new 5g modem (zte mc888) to check whether issue is solved.
In case without success, it seems like an IOP issue between the zte mc888 and GS1100-16. You may use the workaround you found there.
Zyxel_Judy
Thanks to Zyxel team for answers. I still haven't tried the solution, because it is a bit above my knowledge and skills how to configure the modem. But I will try and let you know about the results.
- 588 USG FLEX H Series
- 476 News and Release
