SSL VPN still available?
Knowledge Base | Zyxel
I was wondering if this option is still available with the newest firmware and an zyxel usg flex 500.
I would like to use this for users who want to connect to an internal website with their mobile devices.
I cannot find it anymore i the settings. (SSL vpn of course there is, but the next part i cannot find.)
AFAIK it should. But "their mobile devices", if are Android or iOS devices, won't work with SSL VPN, due to a not-standard OpenVPN implementation used on this feature.
the part application is missing on my usg 500. so i think this is not supported annymore. Then i have find an other solution0 -
You can create users also outside this specific section of interface...
Users is not the problem, but applications0
Hi @Dpj,
Greeting Forum,
The Knowledge Base is for old module/Firmware. FLEX/ATP series no longer support that.
Thank you
Kevin0
- 588 USG FLEX H Series
- 477 News and Release
