How to set the SSID required for the WPA key at the same time of captive portal re-authentication?
Good Day!
Aside from the captive portal re-authentication after set time.
Best Answers
Hi @BMontiel
Once the authentication is expired, the user should input again username and password on captive portal re-authentication page but no need to input WPA key again.
May you share more detail of scenario about your request?
Best Regards
Nami
Nami
Hi @ BMontiel
As @Zyxel_Nami previously mentioned, the AP's client does not need to re-enter the WPA key as the device will remember the key. This is the behavior of the end device. Therefore, your request may not be possible to fulfill.
Kay
Kay
Hi @BMontiel
Best Regards
Nami
Nami
Hi Nami,
Good day!
Thank you for taking time on answering my inquiry.
With regards to the scenario.
After a certain SSID client captive portal re-authentication timer expired. Clients' WiFi connection must automatically disconnect to the SSID and re-connect by inputting the SSID WEP key/passphrase.
regards,
Bien0 -
Hi @ BMontiel
Kay
Kay
Hi Kay,
Good day!
Noted on this. I will relay this with our client.
Thank you so much!
regards,
Bien0
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 495 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 48 Wireless Ideas
- 286 Service & License
- 456 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
