Any change of getting a fanless POE+ switch on the Nebula platform ?
https://www.amazon.co.uk/ZYXEL-Managed-10-Port-Enterprise-NSW100-10P/dp/B0759JN9XV/ref=sr_1_1?ie=UTF8&qid=1537913100&sr=8-1&keywords=zyxel+nebula+switch
Is this the one? Doesn't say fanless in the description.0 -
Hi @AverageJoe
The model of the fanless switches are GS1920-8HPv2 and GS1920-24v2(non-PoE), they actually support NebulaFlex technology in which the device can be managed as standalone or with Nebula cloud.
Thanks @newtype for the link
Cheers!
Bayardo0 -
Nebula_CSO said:Hi @TommyCooper
Our apology for your unpleasant experience about the noisy NSW100-10P at home. Apart from the new upcoming fanless Nebula Switch for the home user as mentioned by @Bayardo, we will also introduce Smart fan feature that the fan speed goes up or down based on the CPU temperature and it is controlled by software automatically. Once the feature is available(2nd half of next year), the user of NSW series simply needs to upgrade the firmware to support the function.0 -
Does anybody know where the GS1920...v2 models are available in the USAVolker0
Hi @GadgetryTech,
The smart fan feature will be available for NSW by December this year. The new GS1920v2 and XGS1930v2 series already support it
Hi @Volker,
The devices are already available through distributors and partners. For Amazon, it's just a matter of time to complete the logistics, we expect them to be available by this or next week
Thank you, and which distributor carries them?Volker0
Hey @Volker ,
You probably can reach out to D&H or Ingram, they should be the first distributors getting them.
If you really can't wait or have specific needs, I think it's best if you directly contact "sales@zyxel.com" they should take good care of you.
Nebula_Bayardo said:Hi @GadgetryTech,
The smart fan feature will be available for NSW by December this year. The new GS1920v2 and XGS1930v2 series already support it1
- 397 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.2K Security
- 96 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 921 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 950 Nebula FAQ
- 425 Security FAQ
- 238 Switch FAQ
- 207 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
