How to set the SSID required for the WPA key at the same time of captive portal re-authentication?
BMontiel
BMontiel Posts: 5
Zyxel Certified Network Engineer Level 1 - Security Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - Security
edited May 2024 in Wireless
Hi Zyxel Support Team,
Good Day!
Aside from the captive portal re-authentication after set time.
Is it possible to also set the SSID required for the WPA key at the same time of captive portal re-authentication?
Thank you and stay safe,
regards,
Bien Anthony Montiel
Best Answers
  • Zyxel_Nami
    Zyxel_Nami Posts: 659 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate
    Once the authentication is expired, the user should input again username and password on captive portal re-authentication page but no need to input WPA key again.
    May you share more detail of scenario about your request?
    Best Regards
    Nami
    Nami
  • Zyxel_Kay
    Hi @ BMontiel
    As @Zyxel_Nami previously mentioned, the AP's client does not need to re-enter the WPA key as the device will remember the key. This is the behavior of the end device. Therefore, your request may not be possible to fulfill.
    Kay
    Kay
  • Zyxel_Nami
    Best Regards
    Nami
    Nami
  • Hi Nami,
    Good day!
    Thank you for taking time on answering my inquiry.
    With regards to the scenario.
    After a certain SSID client captive portal re-authentication timer expired. Clients' WiFi connection must automatically disconnect to the SSID and re-connect by inputting the SSID WEP key/passphrase.
    regards,
    Bien
  • Zyxel_Kay
    Hi @ BMontiel
    Kay
    Kay
  • Hi Kay,
    Good day!
    Noted on this. I will relay this with our client.
    Thank you so much!
    regards,
    Bien
