USG Flex 100 Rev2
Dear @Pook
Thanks for your feedback.
We did remove the SFP port on the USG FLEX 100 due to policy adjustment of the martket.
If you have the requirement of the SFP port, you can consider other products of the USG FLEX series.
Ivan0 -
Does the new revision allow 3 WAN connections still? That's the main concern for me, I can always use a media adapter if required.0
Is this a francy wording for "saving production costs"?Zyxel_Ivan said:We did remove the SFP port on the USG FLEX 100 due to policy adjustment of the martket.
Or for "unavailability of SFP ports"?0 -
Just to confirm the new Flex 200 revision no longer has the option for 3 WAN connections. I would suggest making P5 "Optional" so we get the option back.0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
