Which Wan IP ? Lete7490-M904
JMB_74
JMB_74 Posts: 4 image  Freshman Member
edited January 2024 in Mobile Broadband
LTE7490-M904:
Home/Cllular info: ip address = 10.106.xxx.xxx.
MyWanIP on internet navigator = 185.55.xxx.xxx.
So which is the correct Wan IP ?
Thank's.
Regards.
Fred.
Best Answers
  • mMontana
    mMontana Posts: 1,500 image  Guru Member
    For the router: 10.106.xxx.xxx.
    For internet: 185.55.xxx.xxx.
    Your provider use C-NAT
  • tonygibbs16
    tonygibbs16 Posts: 979 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi Fred @JMB_74
    I think that your ISP probably has the mapping already in their Carrier Grade NAT but will probably not let connections through it to your LTE7490-M904 device.
    What behaviour do you get today if you try a traceroute / tracert to your 185.55.xx.xx address?
    You may need to talk to your cellular provider to see if they will let inbound connections through or not from the Internet.
    Kind regards,
         Tony
  • mMontana
  • JMB_74
    thank's for this information.
    So now, which ip using to access the router from internet ?
    Do I have to create a NAT rule from internet ip to router operator ip ?
    Regards.
    Fred.
  • tonygibbs16
    Hi Fred @JMB_74
    Kind regards,
         Tony
  • mMontana
    Currently none. Ask your ISP/Provider for more info about direct access to your device or your "own" public IP.
