Ideas selecting Radio settings: NWA5123-AC-HD, WAC500H and WAX510D APs
These APs are ZyWALL 110 controlled. What do you suggest for radio settings when having this type of mixed AP enviroment?
6pcs NWA5123-AC-HD
2pcs WAC500H
1pcs WAX510D (will setup this on next week)
You can set "802.11 Mode" to be 11ax (Channel Width: 20/40/80MHz) for radio profile to give WAX510D use the 11ax capability, while NWA5123-AC-HD still can use 11ac capability.
FYI: In case you set "802.11 Mode" as 11ac, both WAX510D and NWA5123-AC-HD will use 11ac capability.
Be a Community MVP: Win a VIP Deal Dash on Your Next Zyxel Purchase!
Hi @Rimfire,
There is no special suggestion for radio settings when having this type of mixed AP environment.
Besides, we have series of FAQ about radio settings to get the high wireless performance as below
1. Maximum output power
2. WLAN Rate Control
3. Limit legacy clients
Although the FAQ for the Nebula version, you still can refer to the feature and the value of parameters for your configuration.Be a Community MVP: Win a VIP Deal Dash on Your Next Zyxel Purchase!
Thanks Judy!
Great info.
At ZyWALL Radio Profile. Is it a good idea to set "802.11 Mode" to be 11ax (Channel Width: 20/40/80MHz) when most of the APs are NWA5123-AC-HD? I mean, the AP is not actually a AX device.
- 390 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 78 Nebula Status and Incidents
- 5.1K Security
- 51 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 331 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 879 Nebula FAQ
- 414 Security FAQ
- 220 Switch FAQ
- 194 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 72 About Community
- 61 Security Highlight
