USG Flex 100 Rev2
Pook
Pook Posts: 153 image  Master Member
First Comment First Answer Friend Collector Nebula Gratitude
Hi Guys
I just want to point out that it is a disappointment this revision does not include a SFP cage. Most of the Flex 100 appliances I manage enjoy using 3 WAN connections, the SFP was great as we directly connect fibre in to the ISP ONT device.
  • Zyxel_Ivan
    Zyxel_Ivan Posts: 410 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Security
    Dear @Pook
    Thanks for your feedback.
    We did remove the SFP port on the USG FLEX 100 due to policy adjustment of the martket.
    If you have the requirement of the SFP port, you can consider other products of the USG FLEX series.
    Ivan
  • Pook
    Does the new revision allow 3 WAN connections still? That's the main concern for me, I can always use a media adapter if required.
  • mMontana
    mMontana Posts: 1,468 image  Guru Member
    Is this a francy wording for "saving production costs"?
    Or for "unavailability of SFP ports"?
  • Pook
    Just to confirm the new Flex 200 revision no longer has the option for 3 WAN connections. I would suggest making P5 "Optional" so we get the option back.
Nebula Tips & Tricks
