RAW performance of USG FLEX 200
V5.35(ABUI.0)
I have disabled all logging and disabled all security services testing locally with a bridge between two PC's one with a HTTP server and the other downloading with Free Download Manager with many threads the best I get is around 440Mb and I'm sure my Zywall 110 is faster then that when I least tested and that's got less SPI.
It looks like the USG FLEX 200 is not fully using all cores with a many thread downloader.
Hello @PeterUKPeterUK said:
V5.35(ABUI.0)
Not very clear how you test it. Did you test the throughput between two lan physical ports? Could you share the topology with the cabling with us?
Can you share the test result of ZyWall 110 with us as well?I'm sure my Zywall 110 is faster then that when I least tested and that's got less SPI.
Thank you.
The test was with a bridge wan1 and DMZ and it seems I was wrong about zywall 110 being faster...or at least I'm now wrong and old firmware when I last tested was faster? Or maybe I tested NAT/routeing performance and a bridged setup is not that fast?
OK, got it. Anyway thanks for your verification for us
. 0
- 602 USG FLEX H Series
- 480 News and Release
