New USG60W - very slow 2,4 & 5 Ghz wireless speed, only 24 Mbps
and WiFi and Guest wizard. Everything is in default settings, minimal config.
The router works fine, but the wireless speed is extremely low,
Why is the router so slow ?
At the moment the fiber net capacity is totally unacceptable;
router if there is no way to fix this..
so the config, and network is OK, which means the problem is related to wireless
Hi @Harska,
Here is our official test report for your reference.
We test is in shielded room using IxChariot.
SpeedTest is not used for the official test report because many factors will affect the throughput such as the test PC, the topology and test tool.
That’s why the official test report is measured by IxChariot in shielded room.
USG60W
Firmware: 4.32(AAKZ.0)
5G
CH100/104 (20/40MHz)
WPA2-PSK (AES) 4Tx: 188, CPU: 75%
WPA2-PSK (AES) 4Rx: 197, CPU: 100%
I also run some tests in our office (not shielded room) using SpeedTest.
Disable 2.4G. Only 5G is enabled.
WPA2-PSK
ISP- 300Mbps
Use iPhone, Windows 10 and Windows 7 to connect to SSID of USG60W to run the throughput.
iPhone (iOS 10.3.3): D/U: 53/67.3 Mbps
Windows 10: D/U: 79/59 Mbps
Windows 7: D/U: 58/60 Mbps
Hi @Harska,Since your test result is different with mine, I'd like to check if it is caused by the configuration file or the test environment. I will send you a private message later to get more information.0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
