Armor G5
KorP
Hi all
Can I switch the WAN port to LAN mode on Armor G5? I need 2 ports 10G + 2.5G
Hello @KorP
Looking at the user guide https://download.zyxel.com/Armor_G5_(NBG7815)/user_guide/Armor%20G5%20(NBG7815)_V1.00_Ed4.pdf linked from https://www.zyxel.com/global/en/support/download?model=armor-g5-nbg7815 and from https://www.zyxel.com/global/en/products/wifi-router/ax6000-12-stream-multi-gigabit-wifi-6-router-armor-g5 that this is not possible.
One option for you would be to put the 10G port into a 10G LAN switch, such as https://www.zyxel.com/global/en/products/switch/28-port-10gbe-l3-aggregation-switch-xs3800-28 or https://www.broadbandbuyer.com/products/42569-qnap-qsw-2104-2t/ or https://www.broadbandbuyer.com/products/36054-mikrotik-crs305-1g-4s-in/
- You have a choice based on number of ports, and whether you want a managed or unmanaged switch.
Here is a review of the MicroTik switch, for example, see https://www.servethehome.com/mikrotik-crs305-1g-4sin-review-4-port-must-have-10gbe-switch/
I hope that this is helpful.
Kind regards,
Tony0
Hello @KorP
Kind regards,
Tony0 -
And Zyxel Support Campus's unboxing and setup video for the XGS1250-12 switch is at https://youtu.be/35su5p__bhc :-)0
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 498 USG FLEX H Series
- 323 Security Ideas
- 83 Switch Ideas
- 49 Wireless Ideas
- 286 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
