Managing APs with NXC2500
I really need some help with a network I'm building.
Hi @alpha099,
Please confirm the traffic between NXC and NWA3160-N APs is ok.
Moreover, with the old firmware version, the NWA3160-N could not be managed by NXC2500. So, in case, your NWA3160-N AP’s firmware is old, you can follow 2 methods to let NXC2500 manage NWA3160-N.
Method 1: Upgrade to 2.23 patch 8 first, and then upgrade to the 5.10
Method 2: Upgrade to 2.23 patch 8, and then go to NWA3160-N login web GUI, and then go to Configuration > MGNT Mode > Choose Managed AP > Apply > Yes > OK
Here is the link to download the 2.23 patch 8 firmware:
https://drive.google.com/file/d/1d0xYGMAuLbK-rU4l2mHLN04zdHWb-728/view?usp=sharing
Here is the link to download the 5.10 firmware:
https://drive.google.com/file/d/1snMnvCXx0FHuQMz__45jm2sCOhAfcc14/view?usp=sharing
Here is SOP to upgrade the firmware via FTP:
How to upgrade firmware to the controller/Access Point by FTP? — Zyxel Community
For other AP models, in case meet this issue, also recommend referring to below step to check.
Please go to ZON > to check whether your AP’s Controller discovery enabled.
If not yet, please choose APs and click to NCC/ AC to configure. To know how to use ZON, please refer to this link
After configure successfully, you should able to see APs on NXC2500 immediately at Configuration > Wireless > AP Management > Mgmt. AP List
Zyxel_Judy
Hi @alpha099,
Zyxel_Judy
Ethan69 said:As I was utilising them with POE, I had intended to keep the APs hooked into the switch; but, when I put the NXC2500 into the switch, I was unable to locate any of them. Even when I reset one of them, I was still having no luck.
Don’t forget to confirm the traffic between NXC and APs is ok.
If you check the traffic and Controller discovery already, however the issue still happens, and your APs are different models, please tell us your AP model to check
Zyxel_Judy
Hello, I saw that you had the newest firmware for both the NWA3160-N and the NXC2500. Do you still have that because I'm not sure if I have the correct firmware to discover the APs with the Controller. I don't have the option to activate the controller discovery on the APs.And if i try to activate the discovery in ZON I can't click the NCC Button.0
Hi @alpha099,
Please refer to the post above to get the latest firmware of NWA3160-N.
NXC2500’s firmware could be download at the official site
NWA3160-N doesn’t need to be set on ZON’s Controller discovery feature, so you can skip that.
Zyxel_Judy
Sorry I didn't understand the Instructions correctly, sorry!
It works now, Thanks!
Thank you so much @Zyxel_Judy! Your solution worked perfectly!
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
