XGS1930-52HP unable to firmware upgrade
Hi @zek,
Welcome to the Zyxel community!
Could you enable Zyxel support access for me to check?
Please go to Help Center > Support Request > Zyxel support access to enable and save. Also, I need your organization name, or I cannot find it.Zyxel Melen0
Hi @zek,
Please go to Help Center > Support Request > Zyxel support access to enable and save. Also, I need your organization name, or I cannot find it.Zyxel Melen0 -
Hi @Zek,
It's been a while do not see your reply.
Did the firmware successfully upgrade?
I did a local test that upgrade firmware via Nebula successfully.
If you still have a problem, please help to collect the tech support and enable Zyxel support.
I will help to check what's wrong.Zyxel Melen0
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 436 News and Release
- 91 Security Highlight
