APs randomly resetting despite config "up to date"
Hi Markus,
The L2UPFrame is something the AP will signal whenever a client roams to another AP. Normally you should see one single log appear when the client traverse from AP A to B, logged by A.
From your previous snippet of logs, most L2UPFrame logs look quite normal except for this HTC client "00:ee:bd:8f:06:07" which I find it strange is that while roaming it always trigger the log twice, on seperate APs, this can only be triggered if the client sends a leaving BSS event to the AP.
Perhaps this one has something to do with it's own chipset, if you know the owner of that client , I suggest you can inform to upgrade it's firmware in case HTC has any fixes on the wifi function.
If you have other logs to inspect, maybe I can take a look.At the moment I see that almost constantly for different clients, even the ones not moving at allIs the Wifi coverage overlapping in those areas?
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
