Bug: DNS no longer delivers internal entries
13»
  • Zyxel_James
    Zyxel_James Posts: 809 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    @baba, the issue should be gone, please have a check, thanks
  • DeltaTechnics
    DeltaTechnics Posts: 1 image  Freshman Member
    I have the same thing going on with a customer:
    USG FLEX 200 with 2 internal networks and one WAN with fixed IP
    I have NAT to a server which has 2 NIC's connected to each internal network. NAT translates external IP to LAN2. NAT loopback is active, so people can use FQDN and reach the server. To enable this using LAN1 as well, we have set the USG as primary DNS, added FQDN and IP of server on LAN1.
    But when connecting, DNS always translate to WAN IP in stead of LAN1 server IP.
    What can I check or do to resolve this?
    PeterUK Posts: 4,411 image  Guru Member
    edited February 2023
    Make sure you don't have a browser with other DNS and have DNS to Zywall
  • baba
    baba Posts: 280 image  Master Member
    @DeltaTechnics thats independent from this Bug. Please open a new topic to get help
Nebula Tips & Tricks
