GS1910-24 console via factory settings
I do not know the interface IP and user name of the device. Unable to access with 192.168.1.1. I connect with Putty, I do ctrl+c. I am typing the following commands.
RedBoot> default
RedBoot > reset
I'm getting an error I don't have much knowledge can you help me in the simplest way
putty speed 115200
putty speed 115200
Best Answers
I'm trying to factory reset the device via console.
Hi @Onur,
You will get these warning messages after factory default GS1910-24 via the console.
Could you help to access 192.168.1.1 as the default IP address?
And you could enter the Web GUI with admin/1234 as the default account and password.Zyxel Melen0 -
Hi @Onur,
The factory default command you used is correct.RedBoot> default (O)RedBoot > reset (O)
After rebooting, it should back to the default management IP address which is 192.168.1.1.
Since you have factory default you switch, could you access 192.168.1.1 again?Zyxel Melen0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
