VPN2S Site to Site VPN (full tunnel mode)
Hi
I've set up a site-to-site VPN between Site A (local Subnet 192.168.21.0) and Site B (local Subnet 192.168.51.0). Both Sites run a ZyWALL VPN 2S with latest firmware. I can access Subnet 192.168.21.0 from Site B. But I wan't all traffic from Site B to pass Site A.
I tried the Option "Full tunnel (Force all traffic to cross the VPN tunnel to the remote site)". The result is no internet acess from Site B.
What do I miss?
Both ZyWALLs are behind NAT.
Screen Shot Site B with "Full tunnel" unchecked (uses local Gateway for internet access). Tried check the option -> no internet access.
Cheers
Hi @mumma,
Regarding to your question "Force the traffic of site B to access the Internet through the WAN of site A"--it's not supported on VPN2S because VPN2S does not support policy route or SNAT over IPSec VPN tunnel. I would like to move your request to the ideas section.
5
Hi @mumma,
5 -
Hi Emily, thanks for the response! Not the response I was hoping for but it answers my question;-) For my use case that would be a great feature. Ideas section sounds good. Thanks!1
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 499 USG FLEX H Series
- 323 Security Ideas
- 49 Wireless Ideas
- 287 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
