USG20 Sys LED Flashing red
VIdeosplicer
Any advice in getting past the flashing red SYS led? Unit worked for a few good years trouble free then out of nowhere SYS LED started flashing. Won't boot, won't communicate via the console. Hard and soft resets make no difference. Powers on, starts to boot, maybe 10 seconds later SYS LED starts flashing. Any suggestions?
Best Answers
had the same issue, it was a defective fan inside, when i replaced it the unit booted again...1
Just bought the exact make and model of the fan from eBay, 12 bucks new. A lot cheaper than having it serviced.
Hi Vldeosplicer
You can make sure console baud rate is 115200 first and restart USG20 again. If it still without any response...then it should be hardware broken.
You can consider upgrading your device to USG Flex series.
https://www.zyxel.com/tw/zh/products_services/USG-FLEX-Firewall-USG-FLEX-100/license-and-spec
Holy smoke, you are right @jellibub! The fan was dead in the unit. As a test, I unplugged it and used a large fan I had around from a old PC build. The fan spinned, and eventually, the USG booted to ready! Well, this was years ago and I have a USG60 and a USG120, but now I know how to get the USG20 back in working order!
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 467 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
