USG FLEX 100 and Apple FaceTime Video
2»
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,518  Zyxel Employee
    Hi @infosecwest ,
    Just conduct a lab test on FLEX100W. I can make / receive FaceTime Video connections in FLEX100W. What is your wifi router mode? Router mode(NAT) or Bridge mode ?
  • infosecwest
    infosecwest Posts: 13  Freshman Member
    problem also occurs on LAN only connections within the same network. Only common factor is the firewall
  • infosecwest
    edited February 2023
    It happens with both phones and mac computers but one of them is 192.168.5.220.
    I have tried calling from outside the network using an iPhone to both a Macbook as well as another iPhone
    Also tried from iPhone (on LAN) to iPhone (also on LAN) - this fails.
    Also tried from iPhone (on LAN) to Macbook (also on LAN) - also fails.
    I have ruled out local WLAN issues by calling to Macbook connected via LAN also.
  • smb_corp_user
    smb_corp_user Posts: 168  Master Member
    Hmm, difficult issue you have got there. Have you tried deactivating the firewall on LAN-to-LAN conncections (or shortly disabling the firewall altogether) to see if that allows any traffic between the Apple devices? Just trying to think through your issue and all I can think of is trying to find a way to eliminate possible sources of obstacles.
  • infosecwest
    Awaiting zyxel support who are doing some diagnostics with a copy of the config
  • Zyxel_Cooldia
    Hi @infosecwest ,
    Could you please help us to confirm what is the I phone IP address when it is connected to AP?
    We would like to check if the phone is in bridge subnet or not.
  • infosecwest
    one of the phones is 192.168.5.220, however it does not seem to matter as others allocated by DHCP in the network (192.168.4.0/255.255.254.0) have the same issue
  • Zyxel_Cooldia
    Hi @infosecwest ,
    Per taked, It seems the issue was solved.
    kindly share some hints for community user.😁
