Can someone clarify what this means?
kmg123
kmg123 Posts: 1
edited May 2024 in Wireless
I have a Zyxel 802.11ax (WiFi 6) Dual-Radio PoE Access Point (NWA50AX) that is connected to a Cisco Meraki Go Network Security (GX20). I've noticed lately my network has random “hiccups” that have become annoying to say the least. I checked the Log for the Zyxel and noticed something strange around one of the hiccups that took place on 2023-02-28. Here are the few lines from the “hiccup”:
205
2023-02-28 11:36:32
notice
Wireless LAN
Wlan slot1 is enabled.
CONFIG CHANGE
206
2023-02-28 11:36:08
info
Interface
Interface lan has been changed.
CONFIG CHANGE
207
2023-02-28 11:36:06
alert
System
Port 0 is up! The link speed is 1000M/Full.
208
2023-02-28 11:36:06
info
Interface
CONFIG CHANGE
209
2023-02-28 11:35:32
alert
System
Port 0 is down!
210
2023-02-28 11:35:24
alert
System
211
2023-02-28 11:35:23
notice
System
This AP successful rebooting by Wireless Auto Recovery process. IP:0.0.0.0
App Watch Dog
212
2023-02-28 11:35:22
alert
System
Port 0 is down!
Line 211 is the line I'm perplexed with. Can anyone help with more information?
  • I have the same problem …
  • Zyxel_Kay
    edited March 2023
    Hi @kmg123
    For line 207,209 and 210 and 212, which mentioned Port 0 up/down stand for the status of uplink signal, this may cause by the Ethernet cable has been plugged into/off from the port, internet connection lost or AP reboot. Line 206 and 208 which mentioned “Interface lan has been changed” usually follows a Port 0 up/down log.
    If the AP detects any abnormal behavior, it may reboot to recover. You'll see a notice about this in line 211. To investigate further, we would appreciate your assistance in collecting the diagnostic file from the AP's local GUI. You can find it under Maintenance > Diagnostics > Diagnostics. Please send us the file via private message, and remember to zip it before sending.
    Hi @Intranetworks
    If you encountered the same issue, please collect the diagnostic file as the step above and sent us via private message. Kindly remember to zip it before sending.
    Kay
    Kay
  • Zyxel_Kay
    Hi @kmg123 and @Intranetworks
    May I inquire if your AP is still experiencing this issue? If so, please don't hesitate to contact us for assistance. In the event that the problem recurs, kindly collect the diagnostic file and send it to us via private message.
    Kay
    Kay
