EOL or not? zyxel usg60W and Switch GS1100-24
isthiscorrect
isthiscorrect Posts: 2 image  Freshman Member
Dear all,
I didn't find a clear answer into website… can someone can tell me if my 2 products:
zyxel usg60W and Switch GS1100-24 are still operational and can be udated, supported? Or do I need to invest on new materials…
Kind regards
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,669 image  Zyxel Employee
    Hi @isthiscorrect,
    Welcome to the Zyxel Community!
    The usg60W ended its service on 2022/12/31. However, we still provide RMA & technical support till 2024/5/16.
    The GS1100-24 is still operational and supported. But since it is an Unmanaged Switch, you could not update it.
    For more information, please reference this EOL list.
    Zyxel Melen
  • Zyxel_Melen
    Hi @isthiscorrect,
    Zyxel Melen
  • isthiscorrect
    Thanks for your feedback! very clear
Service & License Help Center
