GS1100-24 slow speed for devices with speed 2.5Gbps
Maybe you have bad cables?
Update the NIC driver?
Cables and NIC driver are fine. When I switch the Qnap NAS directly to the router, it goes 1Gbps. Only 100Mbps via switch.
One or the other is not doing link negotiation right either something like:
switch see 2.5Gb and run at 100Mb
device see it can't run at 2.5Gb so runs at 100Mb
as the Zyxel switch is Unmanaged with no way to update it you should ask for support by Qnap and see if you can fix the link speed to 1Gb.
or it might be the case Zyxel have to do another version that you have to get a replacement.
Hi @msoltes,
Welcome to the Zyxel Community!
May I know what model is your Qnap NAS and its NIC? Also need the serial number of your GS1100.
Zyxel Melen0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
