AP Disconnect
Steeli
Steeli Posts: 4 image  Freshman Member
edited May 2024 in Wireless
We have over the day some APs witch disconnects from the Controller (NXC2500 V5.20(AAIG.3)). Any ideas?
Regards Matthias
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,315 image  Zyxel Employee
    Hi Matthias,
    The log show “AP Disconnect. Reason:Idle in RUN State….” means in a time, AP don't send to CAPWAP packet to Controller, so Controller assumes that the AP disconnect.
    We recommend you check your switch/ cable/ power adapter as well. Note that the AP’s status is updated every 120 seconds.
    If the issue still happens, we also would like to know your typology with all interfaces to check whether the issue happens with your network. Please provide us the diagnostic files of NXC2500 and disconnected AP to check reason as well.
    Zyxel_Judy
    Untitled Image
  • Steeli
    Hello Judy, i check the physical connections and everything seems OK. I found the following error in the Logfiles:
    2023/3/10 10:12:47,capwap_mgnt_stainfo.c:90:Fail to send STA(ee:fe:46:78:df:2f) Dis-assoc notification to AC!!! Reason: Not Run state or buffer empty
    Can i provide the whole Logs from AP and Controller here?
    Regards Matthias
  • Zyxel_Judy
    Hi Matthias,
    Please provide the diagnostic files of NXC2500 and disconnected AP here or via the private message by clicking to my account > Message.
    By the way, could you share with us APs always disconnects from the Controller NXC2500 or randomly?
    Zyxel_Judy
    Untitled Image
  • Steeli
    I send you the files. This happen randomly with different APs.
  • Steeli
    Actual Firmeware fix the problems
