DX3301-T0 firmware upgrade error
during the DX3301-T0 firmware upgrade I'm facing the following error:
My current firmware version: V5.50(ACEF.0)b2_20220715
The FW version on site: DX3301-T0_V5.50(ABVY.3.1)C0
Downloaded from here: https://download.zyxel.com/DX3301-T0/firmware/DX3301-T0_5.50(ABVY.3.1)C0.zip
Tried to upload the .bin file from the archive unzipped.
Help, please!
Facing the same issue! Would somebody help?
Hi @aleks9989
Welcome to the forum.
Unfortunately, the upgrade is not working for you because the letters are different (ACEF versus ABVY).
This means that your router is running ISP customised firmware, so the standard firmware will not load over it.
You probably need to ask your ISP for newer firmware.
If that is not possible, then you would need to open up your router and reflash it using JTAG I think.
Kind regards,
Tony
Hi Tony,
Thank you so much for an answer!
It is exactly mine situation - I got this router from ISP, but I have moved to another country and can't get any firmware from the ISP cause of it.
So, I would try to reflags it with JTAG as you adviced, but I am not fluent in it, so if you would take me to some link or forum with instruction I will be much obligated🙏🙏🙏
B.r.Aleks
Hi Aleks @aleks9989
I don't work for Zyxel.
You might have to use JTAG to be able to do what you wish to do, following methods like those at https://www.hwupgrade.it/forum/showthread.php?t=2941571 and https://www.hwupgrade.it/forum/showthread.php?t=2941741 and https://openwrt.org/inbox/toh/zyxel/zyxel_vmg8825-t50 and https://forum.archive.openwrt.org/viewtopic.php?id=47364&p=1#p246561 and https://forum.kitz.co.uk/index.php?topic=13939.30
You will need to open the case in order to do this approach, and I have not found anyone who has do it on this model of Zyxel device.
At your own risk.
Kind regards,
Tony0
- 435 Beta Program
- 183 Nebula Ideas
- 120 Nebula Status and Incidents
- 6.2K Security
- 440 USG FLEX H Series
- 299 Security Ideas
- 80 Switch Ideas
- 276 Service & License
- 433 News and Release
- 84 About Community
- 91 Security Highlight
