[NEBULA] VPN L2TP AND CLOUD AUTHETICATION USERS
2»
  • Machado_Taimatica
    Machado_Taimatica image  Freshman Member
    Hello. Same problem here. Can you help me?
  • Zyxel_Chris
    Zyxel_Chris image  Zyxel Employee
    Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 50 Answers
    Hello @Machado_Taimatica
    Welcome to the community!
    Sure, before that I want to know if you have enable the PAP as following screenshot :)
  • TNSinfo
    TNSinfo image  Freshman Member
    Hi Chris !
    Same problem, i got
    [ID] : Tunnel [L2TP_Client_VPN] Phase 2 Local policy mismatch
    in even-log.. and with NCC i cant look the encryption of phase 2...
    Do you have any solution ?
    Thanks in advance
  • Zyxel_Chris
    Hello @TNSinfo
    Welcome to the community! =)
    Is your NSG located behind the NAT server and is it update to the latest firmware?
    You can find it in Gateway>Security gateway, roll down to the status and check if the firmware status is up to date or not.
    Cheers
  • TNSinfo
    Hi ! Thanks for quick answer.
    My NSG is bihind routeur but NSG50 is DMZ of it, and i set up NAT rules for RDP and its work..
    I update the firmware after you reply, but same behavior...
  • Zyxel_Chris
    I will PM you in order to do the further check, please find the message at inbox.
    Thanks~
Nebula Tips & Tricks
