AP Disconnect
Hi Matthias,
The log show “AP Disconnect. Reason:Idle in RUN State….” means in a time, AP don't send to CAPWAP packet to Controller, so Controller assumes that the AP disconnect.
We recommend you check your switch/ cable/ power adapter as well. Note that the AP’s status is updated every 120 seconds.
If the issue still happens, we also would like to know your typology with all interfaces to check whether the issue happens with your network. Please provide us the diagnostic files of NXC2500 and disconnected AP to check reason as well.
Zyxel_Judy
Hello Judy, i check the physical connections and everything seems OK. I found the following error in the Logfiles:
2023/3/10 10:12:47,capwap_mgnt_stainfo.c:90:Fail to send STA(ee:fe:46:78:df:2f) Dis-assoc notification to AC!!! Reason: Not Run state or buffer emptyCan i provide the whole Logs from AP and Controller here?
Regards Matthias
Hi Matthias,
Please provide the diagnostic files of NXC2500 and disconnected AP here or via the private message by clicking to my account > Message.
By the way, could you share with us APs always disconnects from the Controller NXC2500 or randomly?
Zyxel_Judy
I send you the files. This happen randomly with different APs.
Actual Firmeware fix the problems
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
