how to configure ports if access points connected to switch and switch has different VLANS
maheshreddy
in Switch
switch has different vlans and need to tag vlans to different SSID
i have found solution as per the below
Ex : Uplink port : 24
Access point Ports : 1 to 4
VLANs : 200,300 ,400and MGMT VLAN 100
Access points IP VLAN : 400
we need to tag all VLANs into 24 and select PVID is 100
we need to tage all VLANs into 1 to 4 ports and select PVID is 400
and we need to mention VLAN ID in aceess point conifguration
Hi @maheshreddy,
Which model are you asking for?
The uplink port should be VLAN 100 untagged member and VLAN 200, 300, 400 tagged member.
Port 1-4 should be VLAN 400 untagged members if the SSID's VLAN is the same as the access points' management VLAN.
Zyxel Melen0 -
in access point configuration , we are mentioning VLAN ID
- 435 Beta Program
- 176 Nebula Ideas
- 119 Nebula Status and Incidents
- 430 USG FLEX H Series
- 299 Security Ideas
- 79 Switch Ideas
- 276 Service & License
- 428 News and Release
- 89 Security Highlight
