how to configure ports if access points connected to switch and switch has different VLANS
switch has different vlans and need to tag vlans to different SSID
  • maheshreddy
    maheshreddy Posts: 3
    edited March 2023
    i have found solution as per the below
    Ex : Uplink port : 24
    Access point Ports : 1 to 4
    VLANs : 200,300 ,400and MGMT VLAN 100
    Access points IP VLAN : 400
    we need to tag all VLANs into 24 and select PVID is 100
    we need to tage all VLANs into 1 to 4 ports and select PVID is 400
    and we need to mention VLAN ID in aceess point conifguration
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,707  Zyxel Employee
    Hi @maheshreddy,
    Which model are you asking for?
    The uplink port should be VLAN 100 untagged member and VLAN 200, 300, 400 tagged member.
    Port 1-4 should be VLAN 400 untagged members if the SSID's VLAN is the same as the access points' management VLAN.
    Zyxel Melen
  • in access point configuration , we are mentioning VLAN ID
