after ssl connect with secuextender, client cannot see lan1
gianluca
gianluca Posts: 3  Freshman Member
First Comment Sixth Anniversary
edited April 2021 in Security
hello,
i have setup a vpn connection to my USG40.
the connection bring's up, but i cannot see the device on lan1.
the tap adapter remain on 169.254.xx.xx and not take the ip addres of SSL_VPN address range.
can you help me?
thank you
gianluca
  • gianluca
    hi Asgatlat,
    with the new firmware, the vpn is fully functionally.
    and with the old firmware, the version 4.0.2.0 give the access to the lan
    thank you for the idea, and thank to Emily for the firmware
    gianluca
«134
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,442  Guru Member
    edited October 2018
    Hi @gianluca,
    Here are some tips for troubleshooting.
    1. Check if the SecuExtender is the latest version 4.0.3.0.
    ftp://ftp2.zyxel.com/SecuExtender/software/SecuExtender_SecuExtender_Windows%204.0.3.0.zip
    2. TAP driver was signed with SHA2.
    Make sure Microsoft update KB3033929 is installed.
    http://catalog.update.microsoft.com/v7/site/Search.aspx?q=KB3033929
    On Windows, go to Control Panel > Device Manager > Network adapters > TAP-Windows Adapter V9 for Zyxel SecuExtender > Properties > General.
    In device status, check if you get TAP driver error (Code52).
    3. Check if SSL VPN is correctly configured.
    The "Assign IP Pool" cannot overlap with IP addresses on the local networks (LAN and DMZ), the SSL user's network, or the networks you specify in the SSL VPN Network List.
  • gianluca
    Thnk you for response, but i have double checked the setting's, and are correct. this error (no ip to tap adapter), remain in both windows 7 and windows 10. the tap adapter is fully functionally and the KBKB3033929 is installed
    this is my configuration:
    i think i have made the correct setting's, the VPN can connect, but tyhe tap adapter remain on 169.254.xx.xx even if the software say 192.168.50.2.
    secuextender version: 4.0.3.0
    zyxel USG40 firmware version: V4.32(AALA.0)
    thank you
    gianluca
  • Asgatlat
    Asgatlat Posts: 115  Ally Member
    First Comment Friend Collector Seventh Anniversary
    hi gianluca,
    i got the same problem since the 4.0.3.0.
    as i said in my previous post :
    https://businessforum.zyxel.com/discussion/1760/secuextender-4-0-3-0-windows-not-working-vpn-connection-still-ok#latest
    the setup i described in my post is not working on every laptop...
    i think the 4.0.3.0 is blocked by usg, you can transmit data but can't recieved data
  • Zyxel_Emily
    Hi @gianluca,
    I also got the same issue as yours "TAP-Windows adapter remains on 169.254.xx.xx" when using the firmware 4.32(AALA.0) on USG40.
    After USG40 is upgraded to the latest firmware, TAP-Windows adapter gets the correct IP.
    I will send the firmware to you for verification in private message.
  • Asgatlat
    hi Emily,
    i just tried your Firmware (for my Zywall 110), it is working, the TAP adapter got IP adress and i can access to my Lan with SecuExtender 4.0.3.0
    thank you for the fix
  • gianluca
    hi Asgatlat,
    gianluca
  • mmorselli
    mmorselli Posts: 1  Freshman Member
    Hi Emily, I have the same problem with USG20, my firmware is: 4.32(ABAQ.0)
    SecureExtender 4.0.3.0, all configurations as messages above, TAP adapter remains on 169.254.x.x
    What firmware should I use?
    thank you
  • Zyxel_Emily
    The firmware is sent to you via private message.
  • Redcorsito
    Redcorsito Posts: 4  Freshman Member
    Hello:
    i have the same problem. Please, can you send me the latest version of firmware?
    Thank you!
  • Daniel_inroi
    Daniel_inroi Posts: 1  Freshman Member
    Hello, I have an USG60 with FW
    V4.32(AAKY.0)
    Same Problem, get noch IP Adress from the SSL
    Range (Secuextender 3.0.4)
    do you have an Solution? Thank you
