[NEBULA] VPN L2TP AND CLOUD AUTHETICATION USERS
Hello. Same problem here. Can you help me?0
Hello @Machado_Taimatica
Welcome to the community!
Sure, before that I want to know if you have enable the PAP as following screenshot
Hi Chris !
Same problem, i got
in even-log.. and with NCC i cant look the encryption of phase 2...[ID] : Tunnel [L2TP_Client_VPN] Phase 2 Local policy mismatch
Do you have any solution ?
Thanks in advance0 -
Hello @TNSinfo
Is your NSG located behind the NAT server and is it update to the latest firmware?
You can find it in Gateway>Security gateway, roll down to the status and check if the firmware status is up to date or not.
Cheers0 -
Hi ! Thanks for quick answer.
My NSG is bihind routeur but NSG50 is DMZ of it, and i set up NAT rules for RDP and its work..
I update the firmware after you reply, but same behavior...
Thanks0 -
I will PM you in order to do the further check, please find the message at inbox.TNSinfo said:Hi ! Thanks for quick answer.
Thanks~0
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
