XGS3700 VLAN Configuration
benscha
benscha Posts: 1 image  Freshman Member
edited August 2022 in Switch
i'm new witch Zyxel Switches VLAN Configuration and actually i cant configure the XGS3700 as it should be!
On Port 1 i like to have an VLAN Trunk port with my VLAN 10 and the default VLAN1 as an uplink to a Netgear Switch. how can i configure this?
on Port 10-16 i like to have the following configuration:
VLAN 1 untagged
VLAN10 tagged
all the settings are named totally different from my netgear switches and i cant get it work! thx for any help.
  • Zyxel_JonasTan
    Zyxel_JonasTan Posts: 98 image  Zyxel Employee
    Welcome to Zyxel Community!
    Regarding to the description, please follow the steps below to achieve your goal.
    1. Access XGS3700 via console.
    2. Input the following commands:
    VLAN 1:
        XGS3700#
        XGS3700# configure
        XGS3700(config)# vlan 1
        XGS3700(config-vlan)# no untagged 1-9,17-28
        XGS3700(config-vlan)# exit
        XGS3700(config)# exit
        XGS3700#
    VLAN 10:
        XGS3700#
        XGS3700# configure
        XGS3700(config)# vlan 10
        XGS3700(config-vlan)# fixed 1,10-16
        XGS3700#
    3. Save configuration command "write memory".
    4. Verify configuration:
    For more detailed information, please refer to this link to download the handbook chapter 2-1.
    Note: Configure PVID for end device that could not recognize VLAN tagged.
    Thanks for your support to Zyxel!
    Zyxel_Jonas
