IKEv2 Disable Split Tunneling not working
I want to set up IKEv2 VPN Connection where I want my cliënt to be able to use the remote internet connection, so we can use the fix WAN IP on the server side. I set SecuExtender to Disable Split Tunneling and I added a policy route on the flex with IKEv2_VPN as member, Source address the IKEv2 pool and as Next-Hop: Trunk, WAN_Trunk.
However on the Cliënt if I then do a tracert to 8.8.8.8, it gives request timed out. The tunnel works fine, I'm able to access the local server.
I do not remember the setup, but I think you need to add an extra routing rule as well.
If you are using policy-based VPN, please remember to allow 0.0.0.0 in Phase 2.
Hmm, in what section do I have to configure that?
Phase-2 is "VPN Connection" settings.
Phase-1 is "VPN Gateway" settings.
You might have to display advanced options.
Greeting Forum, Please kindly share your config file by private message.
Thank you
Yes I know :) This is my Phase2 config:
Hi @nielsscheldeman ,
Please allow 0.0.0.0/0 in Phase2 policy also ensure VPN client Remote LAN address is "0.0.0.0'
In this way, All traffic will route into Firewall. Thank you
Apologies, but I don't see where I can allow that? client is already configured like that.
Please set the Local Policy to 0.0.0.0/0 . If the issue still persist we can have remote session to assist you.
Thank you
- 384 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 74 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 70 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 333 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 886 Nebula FAQ
- 415 Security FAQ
- 228 Switch FAQ
- 198 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 63 Security Highlight
