IKEv2 Disable Split Tunneling not working
I want to set up IKEv2 VPN Connection where I want my cliënt to be able to use the remote internet connection, so we can use the fix WAN IP on the server side. I set SecuExtender to Disable Split Tunneling and I added a policy route on the flex with IKEv2_VPN as member, Source address the IKEv2 pool and as Next-Hop: Trunk, WAN_Trunk.
However on the Cliënt if I then do a tracert to 8.8.8.8, it gives request timed out. The tunnel works fine, I'm able to access the local server.
I do not remember the setup, but I think you need to add an extra routing rule as well.
If you are using policy-based VPN, please remember to allow 0.0.0.0 in Phase 2.
Hmm, in what section do I have to configure that?
Phase-2 is "VPN Connection" settings.
Phase-1 is "VPN Gateway" settings.
You might have to display advanced options.
Greeting Forum, Please kindly share your config file by private message.
Thank you
Yes I know :) This is my Phase2 config:
Hi @nielsscheldeman ,
Please allow 0.0.0.0/0 in Phase2 policy also ensure VPN client Remote LAN address is "0.0.0.0'
In this way, All traffic will route into Firewall. Thank you
Apologies, but I don't see where I can allow that? client is already configured like that.
Please set the Local Policy to 0.0.0.0/0 . If the issue still persist we can have remote session to assist you.
Thank you
- 347 Beta Program
- 2.1K Nebula
- 115 Nebula Ideas
- 77 Nebula Status and Incidents
- 5K Security
- 44 USG FLEX H Series
- 246 Security Ideas
- 1.2K Switch
- 64 Switch Ideas
- 900 WirelessLAN
- 33 WLAN Ideas
- 5.8K Consumer Product
- 204 Service & License
- 326 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.8K FAQ
- 832 Nebula FAQ
- 402 Security FAQ
- 219 Switch FAQ
- 190 WirelessLAN FAQ
- 45 Consumer Product FAQ
- 136 Service & License FAQ
- 71 About Community
- 61 Security Highlight
